I recently tried my rotary tool on my creality falcon laser 10W, which was unsuccessful. I have now disconnected the rotary and want to go back to laser cutting. It will home itself when I turn the laser on. When I load a project I am getting this message in the console. I am a beginner with the laser and have no idea where to start
e[0;32mI (1317) serial: Line state changed! dtr:0, rst:0e[0me[0;32mI (1422) serial: Line state changed! dtr:0, rst:0e[0m[VER:CV-30.V3.0.24.20221012]e[0;32mI (2488) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 e[0me[0;31mE (2511) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).e[0me[0;32mI (2512) gpio: GPIO[13]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 e[0me[0;31mE (2514) sdmmcfs: Failed to initialize the card (ESP_ERR_TIMEOUT). Make sure SD card lines have pull-up resistors in place.e[0me[0;31mE (2515) sdmmcfs: TF mount failede[0me[0;32mI (2516) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 e[0me[0;32mI (2517) gpio: GPIO[2]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 e[0me[0;32mI (2518) gpio: GPIO[14]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 e[0m[MSG:Axis count 2]e[0;31mE (2629) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0me[0;31mE (2630) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0me[0;31mE (2631) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0me[0;31mE (2633) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0mspindle_pwm_off_value:0.000000 spindle_pwm_min_value:0.000000 spindle_pwm_max_value:1023.000000e[0;31mE (2636) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0me[0;31mE (2638) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0me[0;31mE (2639) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0me[0;31mE (2640) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0mspindle_pwm_off_value:0.000000 spindle_pwm_min_value:0.000000 spindle_pwm_max_value:1023.000000Grbl 1.3a [‘$’ for help]e[0;32mI (2667) serial: Line state changed! dtr:0, rst:1e[0mokokokokokHominge[0;31mE (3937) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0me[0;31mE (3938) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0me[0;31mE (4584) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0me[0;31mE (4585) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0me[0;31mE (4587) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0me[0;31mE (4588) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0mokProject loaded in 8 milliseconds<Idle|MPos:3.000,3.000,0.000|FS:0,0|WCO:0.000,0.000,0.000>okStarting stream
ALARM:2 G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)On or near line 3:Stream completed in 0:00[MSG:Reset to continue]ALARM:2G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
Im guessing a number needs tobe changed somewhere? I thought I changed everything back that was changed for the rotary.
Should my workspace be 400x400 OR 400x415? I have the creality falcon 10w
