Please help me finish my Dad's Christmas Gift! Massive Jitters using Xtool D1 Pro w/ Lightburn
Hi all. I am trying to engrave a golden mug for my dad’s Christmas gift with a personalized message. When I try to engrave the bottom, about 50-60% of the time, my Xtool D1 Pro starts jittering massively. I’ve only seen it happen when using the X/Y axis. I have not seen this happen with the rotary attachment.
It also jitters if I frame twice in quick succession without letting the fan stop first.
Xtool says to stop this:
  1. switch to wifi (not possible with Lightburn)
  2. check the stability of the machine. The machine is using all risers with 4x4s for additional height, but I have to do that to match the height of the cup. I’ve also seen this happen without the 4x4s, and sometimes even with the 4x4s it doesn’t happen. I don’t think it’s a mechanical issue. Sometimes it runs smooth, sometimes it jitters right off the start, sometimes it starts out smooth and then jitter.
  3. check computer specs - done. I’ve got a capable laptop, I don’t think it’s a performance isssue.
  4. check the processing speed. I’m running at 20mm/second. Very slow. Still happens.
  5. Don’t use bitmap for pictures. I’m not engraving a picture, so that’s not applicable.
Here’s a link to imgur with my device settings.
Here’s a link to google drive with a video of it happening, and the LBSET file.
Google Drive
Will post the results of the $$ command in a comment below.
Any ideas guys? I’m really trying to finish this mug before I fly out on Saturday.
$0=1
$1=0.03
$2=0
$3=0
$4=0
$5=0
$6=0
$10=255
$11=0.0
$12=0.0
$13=0
$20=0
$21=1
$22=1
$23=0
$24=25.0
$25=3000.0
$26=250
$27=1.0
$30=1000
$31=0.1
$32=1
$100=100
$101=100
$102=0
$110=18000
$111=6000
$112=6000
$120=2500.000000
$121=300.000000
$122=300
$130=432.000
$131=406
$132=0
ok
ok
MPos:0.000000,0.000000,0.000000,0.000000
My first thought is you’re doing an offset fill on a tiny machine with high acceleration or loose belts. A standard ‘fill’ mode layer will reduce the issue and probably give a better result.
Try switching to Fill mode and let us know if the shuddering remains.
It looks like your belts may also be a little loose.
I’ll check your settings vs the D1 defaults, let me look here…
Hard to find - I’d also be curious if you’ve updated the firmware lately
Your laser must be solidly attached to the table. Sitting on stacked Dixie cups is a sure request to have an unstable machine.
Offset fill is very demanding in the areas of frame stiffness, bench stability, belt tension and bolts being tightened.
Good advice. I got out some 3d printed feet inserts, screwed them into some longer 2x4s, changed to line mode, and the print went thru without a problem. Thank you!
Thanks for your help. The Xtool didn’t have any firmware updates, but I did update lightburn today.
I switched to offset fill and secured the feet with some 3d printed brackets and the print went thru perfectly.
Thanks for your help!
