X5 moves to the left and X-5 to the right
That’s consistent with G0 X200 Y200
crashing to the right but not what I would expect.
Please try the following:
- enable “Show all” in Console
- issue left, right, up, down in Move window
- Return Console results correlating to those 4 moves
Problem got solved thanks to @berainlb
by homing, and then entering
G92 X399 Y0
laser now frames correctly and positions are accurate.
Try to rotate your laser 180 locate this dark by the switch the other side from you will be on your left hand side way from your laptop
the problem was already solved. no need to turn the laser, the laser is in the right position.
