PMW on and off?
So I did some testing with my 60 watt CO2 machine.
I have adjusted the overscan from 1% up to 10% and there is very little differance. At 10% overscan I can watch and see the laser head move past the edge of the engraving, then the laser turns on at the edge of engraving where it is supposed to. I would like to know if the Laser pmw is either on or off, Like 0% power when off and when on it is the set power %.
It looks by the picture below it starts at a higher power then tappers down to the desired set Power. I am do not have the Start Speed settings as mentioned in this document. Troubleshooting: Corners Are Too Dark, Too Light, Or Missing - LightBurn Documentation
Anything I fill has this variation on each end of the travel. I am not able to decrease power as the engrave in the picture was done at 1% power. Also I am not able to adjust speed. I have adjusted the $110 for max travel rate and I have adjusted the $120 for acceleration. nether makes any differance.
I am very curious if I am in the ballpark for my settings? if anyone is willing to compare and share settings?$$
$0=10
$1=25
$2=3
$3=4
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=1
$21=1
$22=1
$23=3
$24=25.000
$25=3500.000
$26=250
$27=3.000
$30=255
$31=0
$32=0
$33=1
$34=1
$35=0
$36=0
$37=1
$39=1
$100=157.138
$101=156.984
$102=160.000
$110=10000.000
$111=10000.000
$112=200.000
$120=500.000
$121=500.000
$122=20.000
$130=425.000
$131=438.000
$132=200.000
ok
You will need to enable laser mode ($32=1), please see:
And because your $30=255, make sure the S-value Max setting in LightBurn is also 255.
On GRBL controllers, a common value is 1000 for both. That may give finer control over the Power % settings.
Yes $30 and S-Mas are both 255, If I set both to 1000, the power is higher and burns more.
Well, a bit of confusion and I overlooked the $32=1 setting. I did a test and the overburn on the ends is gone. Thanks fore the replies
