Popup prompt “Marcos” with text in it that says “Click ‘Manage’ to add custom macros”
When I updated to the latest version I started seeing this prompt “Marcos” with text in it that says “Click ‘Manage’ to add custom macros”. I get this popup in several cases; one of them being when I connect the machine, another when I click Process.
Is there a way to turn this off?
The latest version is -RC 14. I have not seen that happen when I updated. Can you attach a screen shot (WinKey+S) of what it shows?
Thank you! Fixed
Can you share your solution with us? It might help others.
Sorry, thought I had it…. :frowning:
It’s repeatable in multiple place. One way is to open MillMage prior to connecting the USB cable. Then connect the cable and select COM3 port.
If you close this Macro window by a left mouse click on the red X, it should go away and not keep popping up.
You can get it back if you go to the Window menu and enable the ‘Macro’ window.
Or try: Window>‘Reset to default Layout’
