porque se desplaza parte del dibujo al imprimir laser lightburn 2.1.04
because part of the design shifts when printing with LightBurn 2.1.04
While we do some fairly remarkable troubleshooting around here, I’m not certain that we can address what you’re asking for.
The most often seen cause for ‘a shift in part of the design’ is excessive overscan causing a mechanical collision on the chassis of the laser engraver. This causes the machine to lose count of its position.
Excessive overscan can be caused by Overscan Settings or excessive engrave speeds (too fast).
You can see the expected Overscan behavior in the Preview Window in LightBurn.
If you are interested and willing, you are welcome to share your LightBurn project file (.lbrn or .lbrn2) so we can look and see if the cause of the unanticipated behavior is in the file.
It could also me mechanical backlash. Adding an image of the produced work will also help.
