Hello,
Does anyone know how to adjust the speed at which the laser head will move when using the “Position Laser” tool? Right now it seems like the head moves around 50mm/s when I tap a position in the the Lightburn software. I use this tool a lot to setup each cut so I’d like to double that at least. Not sure if thats a LB setting or Ruida setting. thanks for the help!
Rob
