Position shifting mid-job
Thank you for you helpful advice! Here are my settings:
# Stepper module pins ( ports, and pin numbers, appending "!" to the number will invert a pin )
alpha_step_pin                               2.0              # Pin for alpha stepper step signal
alpha_dir_pin                                0.5              # Pin for alpha stepper direction
alpha_en_pin                                 0.4              # Pin for alpha enable pin
alpha_current                                0.4              # X stepper motor current
alpha_max_rate                               24000.0          # mm/min
alpha_acceleration                           2500             # mm/sec²
beta_step_pin                                2.1              # Pin for beta stepper step signal
beta_dir_pin                                 0.11            # Pin for beta stepper direction
beta_en_pin                                  0.10             # Pin for beta enable
beta_current                                 0.6                # Y stepper motor current
beta_max_rate                                24000.0          # mm/min
beta_acceleration                            2500             # mm/sec²
I will increase alpha_current to 0.5 and retry.
I would have never known about these settings had you not mentioned them.
Thank you.
