I am trying to laser a block of text horizontally centered onto and at the bottom of a 8"x14" board.
Executing the file results in the text block being burned from the user origin rather than positioned in the desired location on the 8X14 board.
I must not have some setting correctly configured.
Probably a simple solution, but I haven’t figured it out . . . .
What is the “Start From” mode set to in Laser window? I assume it’s set to User Origin. Change to Absolute Coords or Current Position depending on your need.
