Possible bug in Circular array and apply path to text
Maybe I’m wrong but circular array and apply path to text are not working as intended.
See photo for circular array
and if I won’t sett 45 degrees on start every 90 degrees
Second problem I have is applying path to text. Only way is rotate the path, in my case circle (it is not great solution), but when I’m making empty row ( new space ) in Edit text shape (to change angle of text) the text disappearing after reaching 180 degrees.
Third problem is, if I have to delete the path, text returns in position before applying to path and then cant be removed or deleted.
It was tested on win 11 and win 10 in many scenarios.
I am not understanding what you are trying to accomplish. Need more details here. :slight_smile: For the image below, I placed the first line at the 45º.
Again, not following the request. What are you trying to accomplish? Please show an example of what you are after, and we can assist further using this information.
Deleting the path will disconnect the connection of text to that path, correct. If you apply text to a path, then want to keep the text as applied, yet remove the path, you must ‘bake’ the results by converting the path-assigned text to path (right-click for context menu).
I am not able to duplicate the same behavior. If I delete the path, the text is returned to its origin, but is fully active for edits as text and can be moved or deleted as with all other text. Please provide the exact steps you use to replicate. I will use these steps to see if I can reproduce here.
You can also move the original path used off to a Tools Layer, which will not output with the processing of the job, if that is helpful in your workflow.
