Hi. I am new to this and have a Longer RAY5 (5W) laser. I am getting an automatic beveling that occurs during fill. Notice the higher center line in the vertical line of the E and side border. Is this an option that can be turned off so that the filled part is flatly engraved, with no shallower center line?
Thanks in advance.
Rick
I can see the issue I believeā¦ Wish I had an answer. Maybe someone that uses grbl more than I do can suggest a course of action or debugging to find the issue.
I have 3 machines like yours and a couple other similar types with larger beds.
Since itās always lined up, Iād check mechanical as a start, but I donāt know what else you might try from a settings point of viewā¦
Good luck
That looks like you are using āOffset Fillā, not āFillā. Use normal āFillā and you wonāt get that interior shape.
Thanks Jack for taking time to look at it.
Rick
Thanks Oz. I will experiment. So are you saying the ridge is normal for āOffset Fillā, or just that I can work around a faulty āOffset Fillā by doing a normal āFillā.
Rick
Offset Fill isnāt faulty - it just changes speed a lot because itās following the contours of the shape, and as that happens the laser power varies, so you can get some inconsistency. It was never intended to be a general use replacement for Fill mode - itās meant for very specific cases, like large open frames with lots of empty space.
Normal fill mode uses very simple movement, scanning side to side, turning the laser off & on as needed while keeping the speed very consistent, and will always give you better quality results than Offset Fill, Flood Fill, etc
Thank you Oz! I am new to all this but love LightBurn. I appreciate that you took time to answer.
Rick
