is it possible to invert an image in Lightburn? I see the tab in preview but it does not invert it when when engraving
The option in ‘Preview’ is only for the preview, correct. This is not what you want. Hover your mouse over most everything to pop a ‘Tool Tip’ for that thing.
Instead, open the ‘Cut Settings Editor’ window for that layer, then look to the upper-right of the ‘Image Settings’ section. Flip ‘Negative Image’ ON (green) to produce what you are after.
Thanks!!!
