I was having issues with getting the Power and Speed settings right for a wide range of material… so I produced a program to automatically generate the Power / Speed spread test data. This is a video that explains the program usage and how I use it …
Thank you for sharing this. Please keep us all informed as you continue your efforts.
You have not asked for it, but an idea that came while watching the video - having a switch in your UI that output ‘variable text’ instead of actual settings text at file generation. If no further editing to this file is done to those settings from within LightBurn, you would get the same output as you do now. If, on the other hand, you do edit the settings, the new values would be reflected when the edited file is output.
Variable Text references can be found here: https://github.com/LightBurnSoftware/Documentation/blob/master/VariableText.md#variable-text-in-lightburn
I’ll look at this tomorrow… nice idea…
Hello Paul,
I think it’s a very useful tool you’ve made, is it meant to share it with us here?
Yours sincerely
Bernd
Nice stuff. Could be integrated directly into LB
That’s pretty cool. Nice work.
