I will need your help I have a 20w chinese neje laser who Work well but
I try to cut plastic and i can t in GRBL 1.1 it’s like if the laser didn’t give the max power … even at 100%
And if i select GRBL it cut well but laser don’t stop between letter
So i am lost what can i do to cut without having laser mark between each draw
See picture same file 1 Time in GRBL 1.1 and 1 Time in GRBL
Same for the circle
Have a read of this and then let us know a bit more about your current firmware settings, and how you have set your Device profile / Settings in LightBurn. We can go from there: Common Grbl Setups - LightBurn Software Documentation
There is a lot of information available already on the forum and in the other resources we provide. The search provided at the top of every page can help. We also provide Documentation and some videos that can help as well. Hovering over most everything in LightBurn will pop a ‘Tool Tip’ and you can also hover and hit F1 for help.
