[SOLVED]
Hello! , Can someone tell me how to adjust the Power min when not 0 (In window ‘cuts/Layers’)
Seems to be a bug, when you edit the layer and put the layer to 0% the Min power turns to Zero.
When you reedit the layer and put the power desired, the Power min remains on zero.
It’s not a bug - it’s only available to machines that support that setting when vector cutting (DSP controllers). If you were using a grayscale image, you would have that option.
The issue you have is a firmware setting. In the console, type this command:
$32=1
That enables Laser Mode, which turns the beam off during travel moves. It’s on by default on Ortur systems, so somehow it got turned off.
Thanks a lot for your quick response !
Regards
