Complete novice here so apologies if I’m asking a stupid question! Could you explain please what power min setting in lightburn is all about and why I would want to change this?
Thank you!!
My understanding, which is open for dispute, is that having a minimum power setting that does not match the maximum “permits” the software and controller to reduce power when the laser is slowing/decelerating for corners and other abrupt changes of direction. You may notice, as I have, that the corners of square boxes are often darker and/or more deeply cut than the straight lines. The physics of movement (Science) require that direction changes involve speed changes as well. As the laser slows, the controller will reduce power to ostensibly keep the grade of cut approximately the same.
