Hello, I am new to flat bed laser cutters as I typically run Galvo Lasers. So I replaced the original board with a C3D and when I start LB the laser does it’s start up process and then grinds to a halt making grinding noises.
I have changed the card settings to 310x224mm and speed 1200mm
Have you asked the nice folks over on the Cohesion3D Support Forum:
They have a lot of great information to help you get the hardware configured correctly. They also have write-ups on getting LightBurn set up with their equipment as well.
Thank you all sorted. I changed a few setting on the card and now that part is fine. Now I have another problem and that is, the laser is continuously on/firing - I have posted a help request on the C3D forum but no help so far!
