Power Scale 'Breaks' when traveling at a Slow Speed
I am trying to build a sample card using rows of boxes each at a set speed with power scaling from 10% to 100%. All the rows work fine until I get to 10mm/s where the Ruida Controller using min/power. I want to create two rows below 10mm/s, I can create 20 layers but is there a way to use power scaling to scale the min/power?
The only way to do this would be to lower the ‘Start Speed’ setting in Edit > Machine Settings to a value lower than 10mm/sec. That value is the point where the Ruida begins power ramping.
