When I load the setting test file, it does not change the cut/power settings to the correct settings from the file. It keeps the settings that I have changed over the past year or so. Setting the cuts to default does not help. Is there something that would allow me to import the settings from the .rd or lightburn file?
What file are you referencing here?
This is worth review, https://lightburnsoftware.github.io/NewDocs/UI/CutSettings/index.html
The test file provided by Boss. Since I changed the power settings on most of the colors, when I load the file , it does not change the power settings to what they should be. Is there a test file available that will change the power settings?
