Dear forum members,
I feel that my JTech 44W laser has become weaker than before. Does anyone know the power setting
(in the $$ console command) that I can check?
Kristian
As a start read the following doc:
@parsec I believe has it.
What most Chinese manufacturers depend on is the user has no way to check output laser power. As they consistently advertise more power than the laser can produce or it’s maxed out.
Go find a power meter … Unless you physically change a setting, I know of no software that changes these settings, except the user.
Some type of instrument is needed to measure power, it’s next to impossible to ascertain what kind of power it’s producing.
Some of these modules are based on input current, not output wattage. If they do, it’s buried in the other specifications. I think you should put both on the module itself.
