Power shut-off and restarting the job
Hi all! When I am running a LASER job and the main power is shut off - how to restart the job at the exact same position as before? Of course I can use a battery buffer (time limited). Is there another solution? Can I manually move the laser to a start position and continue the job there? Any other idea?
Thanks!
Here is an option that might help. :slight_smile:
Thanks, Rick, this is great! Definitely it helps :grinning: :pray:
Another trick used prior to coding the ‘Start here’ feature. You can flip the fill scan 180º to have the job start from the opposite end, watching closely, and hitting stop as the new cuts meet the old.
Another useful hint. Thanks a lot.
