Longer Ray5 with a 10 watt engraving module 120v-240v input 12v 5a output power supply burned out, will my replacement power supply says 120v-240v 19a 9.47 output damage my unit?
Charles Pearson
Charles Pearson
Looks like 19v 9.43 amp. Wrong voltage. Don’t use it. Higher amp output is fine, but the voltage must be correct.
thank you for the info, kinda thought myself, just needed a second opinion. Again many thanks
That’s a really odd output value, are you sure?
Best guess is it’s a power supply from an ASUS laptop with those numbers.
