I’m in the process of changing over my power supply, the new one is installed however the connectors are different . I’ve matched the current wiring, however the laser is continuously fires when turned on. Can someone please advise what wires should go where if possible?
That laser power supply is a 40W (M40) and won’t really work correctly for your machine. The lps is for a K40 type and isn’t directly plug compatible.
I’d suggest you send that one back and get a regular lps for your type of machine. Such as…
It is plug compatible and will make for a better lps, usually has internal current limit controls and will be easier to troubleshoot if the need arises.
Unless you have a powerful motivation to do otherwise, get an exact, plug-compatible replacement power supply, insert the connectors from the old supply, and move on.
So that we can help you a bit more, what does the old power supply look like? In particular, show us a picture of the data plate on it.
Amazon’s search tends to return irrelevant junk, so you must eyeball the results to pick out the 50 W power supplies that (I assume) match the tube you just installed.
Those supplies generally do not have the additional four terminals to the right of the six-pin control block for the +5 VDC and +24 VDC supply outputs. Were those terminals connected in the machine’s original configuration?
