Hey guys! I am almost a complete newbie, we recently got a laser from eBay that had a relatively fresh tube installed.
I guess there is an issue with it, so I was trying to figure that out, and it completely slipped my mind that I should back up settings of the controller straight away.
We were really unfortunate to have a sag (brownout) at our premises, and the controller has lost all its settings.
I stupidly did not save the parameters when I first started the machine. The laser is no-name, pretty much, but I know the controller and the tube. Ruida rdlc320-a + reci W4 100w.
I have some settings saved in screenshots that the seller has sent me, and I know the tube.
Like :
Parameter Value
Laser Attenuation 0
Machine Type Normal
Feed Mode Single Direction
Broken Delay 0
Transmission Mode Belt + Step Motor
Z Function Platform
Enable Para
Water Protect No
If Protection On No
If Blowing No
Min Power 2
Laser Frequency (KHz) 60
Laser Attenuation (%) 0
Max Power 98
Laser Mode Glass Tube
Laser Config One Tube
Home Position 0
Accelerate of Emergency 1000
Accelerate of Keying (mm) 1000
Start Speed of Keying (mm) 5
Breadth (mm) 1200
X Axis Settings
Direction Polarity Negative
Limiter Polarity Negative
Keying Direction Negative
Control Mode Pulse+Dir
Enable Limit Trigger Yes
Enable Home Yes
Step Length (um) 2.79
Acceleration (mm/s) 1000
Jump Off Speed (mm/s) 5
Max Speed 1000
W4 Reci
Ignition Voltage (KV) 24
Recommended Current (mA) 26
Target Power (W) 100
Max Power (W) 130
However, I need help figuring out the pre-ignition frequency parameter for the machine.
If the laser frequency originally was at 60 KHz, is the 10-20 KHz the correct setting for the pre-ignition? Am I missing anything important that might blow me up on the spot if it is entered incorrectly?
