Is it possible to save/change the default values in the camera image trace tool for things like smoothness, threshold, cutoff, optimize and sketch trace, so that I don’t have to manually change them to the same thing every time?
Are the values read from some config file like the prefs.ini(they don’t seem to be in prefs.ini), that I can edit or are they hardcoded in?
You can save in adjust image, but trace image is more of an art than just setting and forgetting. Each trace usually needs to be tweaked in different ways and even done in several passes to get a decent trace.
