Hello guys,
my first laser is on its way an I´m looking for a good software which supports OSX and the german language. So i found Light Burn, downloaded the trial version and did some presale testing.
I like the software a lot but have one simple question:
When i click on the preview button nothing happens… is this a bug, wrong setting or is it just because no laser is connected ?
I have a Mac running OSX 10.13.6 (17G7024) and I have never seen this before. Once you click the ‘Preview’ are you able to then do anything else within LightBurn? Please try and provide details about your setup and step-by-step instructions so we can try to recreate.
Does the same happen if you pick ‘Preview’ from the ‘Tools’ menu or press the Alt + P keys?
Let´s say I´m drawing a simple square and then click on the preview icon in the top toolbar (just like in some simple light burn tutorials on youtube) then just nothing happens. It´s not like something is crashing, it´s just not working.
Alt + P is also not working and under tools the same.
I just thought it´s maybe because no laser is connected or set up.
Thank you for reporting this. As mentioned, never seen this before so I will generate a bug report. I test all the time without a connection on multiple systems and laser configurations, so this should not be an issue.
I may have misspoke. Do you have any ‘Device’ defined at all? LightBurn needs at least one single device defined and selected (you do not needed it to be “connected”) to know what features are supported and should be displayed.
We are talking internally about displaying an error message if this occurs to provide clarity and the appropriate solution.
Translation is tough - every time I alter or add text, it needs to go through the translation process again, and things change relatively quickly. I’ll be releasing another language pack for the translators soon.
