I had similart probblem before. There must be a setting enabled addlling this kerf and I donmty know where to disable it. As you see in pics I’ve uploaded itrs adding an offset or kerf again . Can you tell me where to turn this off and how I remove it now with this project
Im trying to cut out text. Do you need to do something before sending it to laser
Send a screenshot of your cut layer properties
The prob turned ouyt to be kerf. myu kerf should by 0.08. Howerver, when I set my laser to run 5 passes I think it was applying kerf times 5 too. Is this correct. Because I can set kerf to 0 and everything great
