I created a file on Windows 11 and run the preview time. It was 7 minutes. I transferred the file by both USB and Dropbox to my MacBook Pro. In each case the Cut distance is 16000+ mm on Windows and 906000+ on the Mac. Any ideas why this is happening? I am using xtool d1 pro 20w.
Edit → Device Settings → Read from Controller
These values are used to compute the preview times. If they change when you read them, it’ll probably be more accurate.
Good luck
Perhaps it’s a difference in the cut optimization settings.
Have you copied all the LightBurn configuration files from the Windows box to the Mac?
This walks you through all the steps:
If the results still seem off after you match up the settings, we can dig deeper into the situation.
Copying the preferences fixed the issue. Thank you so much.
