Hi all. The cut in my project didn’t went through the sheet. I tried to recut with the print and cut tool. I draw 2 registration marks in LB and moved the laserhead to the exact location as marked in LB. Opened the tool scan and cut clicked on the wizard and tried to set the first mark. No respond What is wrong?
Print and Cut matches marks in the LightBurn design to physical marks on the material. Those marks must have known / exact positions with respect to both the design and the material.
You cannot add them to the design after the failure, because there are no matching marks on the material.
The doc explains the process:
Hi. Rather strange. I watched this video https://youtu.be/ddRW12VKIwY?is=Oh8l8IQ28nWdTesH In which has been explained how to re-cut afterwards.
Please feel free to watch this video
Kind regards Ron
Per the transcript:
you will need two registration marks for laser alignment these can be added in the original design or in light burn if there are two distinct Corners in your graphic
As the design did not originally have those targets, you must put targets on existing corners that you can locate on the partially cut material.
You then select a target in the design, jog the laser to that corner, set it as the first point, and do the same for the second target / corner.
I find it’s easier to use Position Laser to a corner / target, slide the material to put that corner / target at the laser position, then do the same for the other corner / target, without invoking Print and Cut.
A crisp picture of the material and a screenshot of the design will help us give better recommendations.
Hi Ed
Thanks a lot for your help. What I forgot is to click and keep the cursor on the mark in my design while moving the laser to the same spot on the project.
Kind regards Ron
