Print and Cut for multiple copies of same jobs
Is there a way to use the Print and Cut function to cut two or more copies of same jobs without having to repeat the register process each time ? for example if i print 10 copies of one job and i align the register marks with my laser for my first cut, at the same time i put lateral guides on two sides of the job so i can locate the other 9 copies on the same posicion as the first one, i can cut the first copy and then use a repeat function for the other 9 copies ?
If you can position your copies 100% just like No. 1, it should be possible. But if it is very finely detailed I do not think you hit the different copies perfectly.
