Hello,
I am having some difficulty using the Print and Cut feature. As shown in the illustration I have attached is the Lightburn interface and my actual results. At figure 1 and 2 I set the target positions and I made sure the red dot was centered on each target. Figure 3 shows the dimension of the expected cut. Figure 4 shows the actual cut size. The height and width are both incorrect on the finished product. I tried both scaled and unscaled aligned output to target with the same result each time. I also turned off Use selection origin and or Cut selected graphics during an earlier test. same result Am I missing something pretty basic here? Rudia controller. Nova 63 Thunder. Any help would be appreciated.
M
