Print and Cut Not Aligning
I’m trying to cut a project 3 ft long - so using the print and cut feature. After I cut my first of the three parts (i broke the project up into 1 ft incriments) I go to align my laser with the registration marks; however, after i move my laser head to the mark and choose “set first target position”, i then frame the registration mark and the laser head moves away from the registration mark and frames in a different position. I tested this multiple times and can’t seem to get it to laser in the right area. Any ideas why it’s moving off the registration mark?
Don’t do that. Move the laser to the first registration mark and set position, then highlight the second registration mark and move the laser to it and set second registration mark. Then select Align outputs, no scaling. It should then show print and cut ready in the laser window. Only then can you frame it.
Thank you!!! This worked! I didn’t realize I had to do this last step. You saved me!
