Good Day. I’m not sure if I’m in right place to ask for help.
I have home made laser cutter with CNC shield Arduino together with Lightburn
1.6.03.
I try to use Print and Cut features in LB.
I do not know why - but every time I start LB and laser the cut is offset from target down by about 10mm. I did try to relocated target positions but with no luck.
Can you help me - please
Sorry everybody - problem solved - it was totally my stupid mistake.
Nothing to do with LB. LB is fanatic software.
I’m very sorry.
How did you solve this problem? I have the same problem as you, could you tell me your solution? Thank you
