Print and cut Wizard
Can the Light Burn team modify the tool (Print and Cut Wizard) to have 4 points if the user wishes? I make cuts on laminated stickers that are glued to MDF and many times the sticker is distorted due to the lamination. 2 points are not enough.
Google translate.
Thanks.
If you have an area where two more points would be safe, why not put your points there?
How is Lightburn supposed to know which two points age the good ones?
