In my software version there are two Align functions: Align and Align (scaled). I did not find that mentioned in the doc, maybe a new addition. What is the difference and where would I use which?
Align (scaled) allows for the scaling of the design to fit the size inferred from the target alignment process. This allows for designs to be aligned to cuts that do not fit the original scale of the design.
You would use Align without scale if the expected output is the same scale as what is seen in the design in workspace. Basically, this is how LightBurn typically behaves. What you see on screen is what you get in output.
Thank you. That answered the question.
