I select my first point, go into P&C dialog, all is good, jog to my second point. Now I need to move that position over my work with very small movements using move. Well you cannot do this without leaving the dialog, make your adjustments then reenter the dialog to continue. Question why getting forced to quit the dialog in the first place?
I’m not home to test, but I believe that if the “Move” window is visible, it’s possible to move the laser to the desired point.
Assuming that’s not the case, what I managed to simulate here is that even if the “Print and Cut Wizard” window is hidden, when reopened the process continues and doesn’t start over.
Can you confirm if the same thing happens?
You are correct the move dialog will take the moves correctly. I am using a little keypad with shortcuts to move and that is what does not work. Thanks
