Print & Cut on multiple axis?
Is it possible to use the print & cut feature for a project that is bigger than both of your X and Y cutting lengths?
For example, my cutting area is 400mm x 400mm but could I use P&C for a project that was say 800mm x 800mm? Are there any tips for doing this?
Yes. You’ll just need to include registration marks along all the edges that you’re extending. Or some other natural part of the design that you can reference.
You’ll need to break up your work into as many pieces as required to complete the burn with the size of your laser.
Amazing, thank you!
