Print & Cut starting in wrong position
I use print and cut regularly via the wizard after updating software today the cut is starting nowhere need the intended position , so I will reload last version and see if that clears it, just wondering if anyone else has had this problem?
Try importing your preferences first:
Sometimes when you update LightBurn, Windows will do strange things, like ignore your preferences/settings. Go to File>Preferences>Load Prefs Backup>Select an option that worked for you previously to get your settings back.
