Posting again on that topic since we are in 2026 now, previous similar posts are closed and the problem hasn’t been solved.
The problem : The printing system in LB resizes the content of the workspace to fit in one paper page, instead of printing it at real size on multiple paper pages as it should.
Add to that that the workspaces are now named “pages”, which add even more confusion.
@LightBurn do you plan to implement a proper printing system at any moment ? Because the current one is useless.
‘Pages’ or tabs or workareas are not meant to be conflated or confused with actual pieces of paper.
The original intention of the Print features were to allow for ‘printing’ to Epilog, Trotec, ULS, or GCC, as they use a print driver to output LightBurn generated designs, as explained here
Those laser systems use custom page sizes implemented at the device property level of your printer in your operating system to make sure the design is output to scale.
You can add custom page sizes in both MacOS and Windows, but splitting the larger/'Full Size" page into multiple Legal/Letter/A4 sized sheets of paper would need to be handled by other software.
The sewing community uses Adobe Acrobat to split up and print out sewing patterns in the same way, but broadly speaking our Framing feature is what we’d rather you use to see if an engraving would fit on a given workpiece or material.
Alternatively, you can use the “Cut Shapes Passthrough” method as shown in one of our older videos here which may be a bit more of a process, but should be able to allow you to achieve your goal.
With all that said, we welcome suggestions for new features at https://lightburn.fider.io/ and we’d suggest you make a post there detailing any feature you wish to see.
We use Fider to help us choose which features are most important for us to develop next.
Unfortunately it doesn’t resolve the subject of this post. If the print function wasn’t intended to work as the “print” in any other software it should have been named otherwise. Allow me to mention that the documentation does not mention Epilog, Trotec and other machines, it just states that printing will use the default print dialog of your OS.
There is a warning though : Page Size Warning
Be aware that the page size is controlled by the print dialog, not by LightBurn. If your work area is larger than the paper selected for printing, your design will be scaled to fit on the paper.
But that resizing is made by Lightburn instead of spreading the print over multiple pages as it should.
Anyway, it seems clear that it will NOT be solved anytime soon by the LB team and that laser and inkjet printing of workspaces will have to take place in some other more capable sofware.
The only software I have that would print page segments is MS Excel. If the spreadsheet is too wide for one page at the current font size, it will wrap the extra columns to the next page.
You still cannot just tape the pages together. It is a rare printer that will print all the way to the edges of the paper. Like @joed said, using other software, like maybe Acrobat, specifically designed for printing large objects in small pages is your best bet.
While it doesn’t resolve the subject, it does explain our stance on the matter. There don’t appear to be many users that have the assumption or use-case that you do for printing from LightBurn, and I offered a path forward through Fider. If the need for change can be represented there, then the change will be moved up the priority list for the devs.
This is the default action for most software when you go to print, aside from Acrobat and Excel as @MikeyH mentioned. If you think LightBurn ‘should’ do anything differently, and other users agree, that is the whole point of Fider. But if Adobe decided it was worth a whole other software package to split prints and pages like Acrobat does, we can’t assume doing so would be a small task to add as a feature for a function of LightBurn.
I don’t want to make a mountain out of a bump here, but any and every software I use prints multiple pages when necessary. Word does it, Adobe Illustrator does it, heck, even the very browser I’m typing this in does it.
Now, I can understand that this is probably complex to implement and that there are probably other urgent needs waiting for LB dev tem. But a proper way to print a workspace with proper dimensions would simplify a lot the print and cut funtionality. Just saying.
