I’m coming from the Easel software, and want to set Millmage to follow the same functions. I see where you can add the coolant option (it’s the port on my black box I use to turn on the dust collector), I see the probe set up but I don’t see where to put the thickness of the probe plate at. I also need after the XYZ is set to be able to raise the Z axis to install the dust shoe prior to starting the job. I may be missing where I can be done, any help would be greatly appreciated. I’ve been using Lightburn for some time now and think it works great.
thank you
