Probing only works on Z axis. Probing attempt on X axis the cnc head continues to move in the -X direction until it errors out. Machine set for GRBLHAL. Using AutoZero Touchplate which works flawlessly using Gsender from Scienci Labs
Can you share a screenshot of your probing config, so we can take a look? Alternatively, exporting your device bundle would be great as well (Devices button > Export)
devices export.mmzip (4.9 KB)
I hope to be able to use the Auto Zero Touchplate from Sienci Labs that I use with my Longmill MK2 CNC. The block uses the inside surfaces for probing the X and Y axis. Is there something in setup that I am missing?
Here is the reply I received from Sienci Labs regarding the “Auto Zero Touchplate” which I use on my Longmill MK2. -
The AutoZero touch plate is usually compatible with 2-wire, NO probe connections.
We also have macros that you can load into your specific g-code sender, in order to conduct automated probing processes. You can find these here: Touch Plate - LongMill MK2 CNC
There are several G-code macro samples, however I have only succeeded in getting either the X-axis, or the y-axis macro to work. A macro that will set X, Y, Z in one step would be very nice. In the mean time I continue to do the probing using Gsender and then set the Millmage workspace to 0,0,0 and move forward.
Hi all, I’ve had my LongMill 48x30 for a while now but have been doing very basic projects while I wait for Millmage since I really like LB for my laser. Regarding the probing with the auto-zero touch plate from Sienci, are there any new advancements to utilize it out of Millmage, or would I be just as good to continue using their GSender? It works great there.
Hoping to really get going on designs and if I need to export GCode out of Millmage, that’s fine. Just figured I’d ask.
Thanks.
I’ll give that probe block a go during the next few upcoming projects. Good looking out!
Any luck on this? Would really like to use the Sienci autozero touchplate with Millmage.
Same. I really like Millmage for design, but it just may take a while to catch up to the long-term SW packages already out there.
@eilerstg we aren’t rolling out a full advanced feature set on first release simply because unlike most SW packages out there, we are supporting CAM and control on a wider range of controllers than other senders. And given the risk of injury/damage, we want to take it slow and be absolutely certain our logic paths and gcode outputs are consistent so our users can expect a (relatively) safe operation of their upside down blenders on a robot gantry. We will get there, but understand that we’re being cautious about this.
Thanks for the reply and update! Understood and makes total sense.
We’re going as fast as we can! As an Altmill user, I also want this, so you’ve got a vote on the inside ![]()
