Hi,
I have imported a DXF of the profile I am trying to cut. The cut layer is set to take 4 passes, but rather than cut the entire profile completely and then repeating, each line of the profile is cut 4 times.
For example if it was a square the bottom horizontal line is cut 4 times, then the right vertical line 4 times …and so on.
If I create a square using Lightburn then it is cut as I would expect (the entire profile cut rather than each individual line)
I am creating the DXF in exactly the same way as I have done before without any problem, so I think I must have changed a setting somewhere by accident.
Any help on what to try would be great.
Thanks,
Geoff
