Hi
I’am using a Vevor l4040. I did some tests which were all quite satisfying
Today I tried to print something I creayed. And… all the layers were engraved “melted”.
What did I do wrong?
It is supposed to be a medal
Thanks for your help
Hi
Was the plywood well fixed?
Run the file in the following post then post here pictures of the output:
Also post your project .lbrn2 file for us to have a look.
Hi
Thanks
Here is my file
MEDAILLE.lbrn2 (216,1 Ko)
I don’t know why the cuts are not all axed correctly ?
Your project file seems ok.
You have to run the
Then post a picture .
Likely your laser has mechanical issues,
Check here:
Thanks
I’ll print the test file and alsoo look at possible mechanical issues.
Do you think I need to reset x and y zeros ?
For now just test the laser mechanics.
