Oh, I have the full Lightburn installed and I’m using the LAN connection direct to my laptop. Lightburn controls and runs the motion correctly, but doesn’t turn on the laser.
I was trying to look up the solution in the forums.
What is the Min Power setting you’re using? If it’s too low, the beam won’t turn on.
Check that you have water flowing through the machine, if it has a water-protection switch (though that will usually sound an alarm)
Also check that there isn’t a second switch on the machine itself that enables the beam. Often machines have a power switch and a laser enable button, and sometimes the door switch is tied to this.
Does it fire if you hit the Pulse button on the controller itself? If not, it points to a possible hardware or wiring issue. If it does, then it’s more likely a software or settings problem.
Power is set to 30%. I do get a pulse when I press the Pulse button on the control panel.
I ran the same job, settings, and LAN connection on RD Works software and runs fine. Laser turns on and cuts. I suspect I’m missing something in the setup.
I asked “What is MIN power set to?” - important distinction.
Ah, I’m I see what you mean. I had Max of 20% and Min of 0.00.
What a dummy.
Changed it to Max 30% and Min of 25% ALL OK NOW!
Thank you!
I apologize for the late reply. After this reply from you I found my mistake right away. I answered promptly, but didn’t press the Reply icon.
