Hi
Just updated to 1.1.04 and my laser won’t move in any direction except for up and down. It worked fine before update.
I have a J-Tech 7Pro Laser on a X-Carve.
I have a customer job waiting.
Thanks
Greg
Hi
Thanks
Greg
If it worked fine before updates then the LBpref file should be intact.
Open/run/launch LightBurn without a project.
Click File
Click Load Prefs Backup.
Select a file with a date when you are certain that your XCarve was working and click Load.
It should be that simple.
Were you recently using a Rotary device?
If so, the solution may be switching off Enable Rotary in the Rotary Setup box.
