Problem on the size of cut objects
Hi, I have two problems with Lightburn since I installed version 04.
1st issue : the design measures do not correspond to the cut. with RDworks I know the procedure to correct the measurement difference, how can I do it with LB?
2nd issue : I don’t know if the second problem is connected to the first one (maybe) I realize many names in italics, if I cut them with LB they lose a lot of details, almost as if LB added in offset of 1 mm or a little more, the same file if I draw it with LB and then cutting it with RDworks is perfect
someone know kow i can set LB for solve both issues, thanks
It sounds like you might have a kerf offset applied in LightBurn - that could easily cause both issues.
