Problem resizing slots
Having an issue with slots. On a drawing with several slots, all 3mm, only a few actually appear to be editable.
Screenshot 2023-11-26 at 11.50.30 PM
I’ve checked there are no extra nodes or rounded corners in the drawing. The drawing seems to be closed as I only see one green node. No errors are present in the dialog box.
What am I doing wrong? (LB 1.4.03, Mac) Drawing:
slots.lbrn2 (15.7 KB)
Thanks.
There are several unique issues with the various slots. Here are some of the things that I saw:
  1. Slots must be made up of only lines. I saw at least one slot where one side was actually a curve.
  2. Some of the slots have two very tightly spaced nodes at the corners. Delete the extraneous nodes.
  3. I found one oddly formed slot where one corner of the slot had 2 overlapping nodes.
You can easily cleanup all of these issues by going to Edit->Optimize selected shapes and doing a very conservative “Fit shapes to lines”. That should cleanup most of the slots without distorting the shape too much.
Thank you. Much to my chagrin I missed the very close nodes in my review.
I did use the optimization tool and it fixed my issues. I greatly appreciate the help.
