ned
(ned)
October 17, 2022, 9:13pm
1
hello all
nothing good >>> cut today but after first figure at normal speed , the second one goes alone 13mm/s i don’t understand and i change nothing in setting , yesterday all work good .
i try by usb , by sending to laser and with usb key , i’m running on ruida6445G firmware RDLC-V15.01.2
thanks
100 mac 48mm print zone 36mm_backup.lbrn2 (97.0 KB)
jkwilborn
(Jack Wilborn)
October 17, 2022, 9:30pm
2
Are you saying the first thing cut on the first layer works ok, but after that it slows down?
I don’t see anything in your artwork. I’m not used to doing multiple passes.
What kind of watts does your laser produce?
How thick are you cutting.
ned
(ned)
October 17, 2022, 10:30pm
3
I mean the title round the first one is cut perfect speed after the second one slow down , is the same layer .
the issue come from Z down each pass , when I just ask 2 pass he do it at normal speed.
my laser is 100w recci and I can cut 2 times the material , the problem is not power source , is software ruina or light burn .
thanks
jkwilborn
(Jack Wilborn)
October 18, 2022, 1:03am
4
I don’t have a z axes, so I’m probably unaware of what issues it may cause. I wouldn’t think a Z change would effect the speed.
system
(system)
Closed
November 17, 2022, 1:03am
5
