Hi.
I have a problem.
The cut does not finish. I attach a photo.
thanks
What laser machine and operating system? What are your cut layer settings?
It looks like min power may be set too low.
grbl 1.1h
machine aliexpress
lightburn 0.9.09
win10 prox64
$0=10
$1=25
$2=0
$3=1
$4=0
$5=0
$6=0
$10=1
$11=1.000
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=0
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$100=80.500
$101=80.500
$102=80.000
$110=5000.000
$111=5000.000
$112=500.000
$120=500.000
$121=500.000
$122=200.000
$130=500.000
$131=500.000
$132=200.000
ok
That looks like a diode that hasn’t been focused. Since it’s visible light, it is mostly reflected by white paper, and if it is not focused, it won’t burn through. The laser power is reduced when it slows down at corners. Focus the laser to the finest point you can using the ‘Laser Fire’ button in LightBurn to fire the laser at a very low power setting, and twisting the focus ring at the bottom of the laser. That should help.
