I’m hoping for some help here, I have a Yora 6550 laser engraver. When I first got it it worked fine. Now it barley responds. When I have it on Current position it will move once when I hit the move button, when it is on User Origin I get a warning that says I am out of the usable work area. And when it is on Absolute Cordinates it will move freely, but i still am not able to run any jobs.
I am hoping someone can help me. Thanks
Start here to ensure you have everything set correctly: Adding a Laser - LightBurn Software Documentation
Continue through the documentation until you complete the Simple Project, to get things working as expected and a good overview of LightBurn.
And this is worth review as well: Common Grbl Setups - LightBurn Software Documentation
This is what the machine is saying when i try to make a project.
Starting stream
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 2:
Stream completed in 0:00
[MSG:Reset to continue]
ok
Grbl 1.1f [’$’ for help]
[MSG:’$H’|’$X’ to unlock]
[MSG:Caution: Unlocked]
ok
ALARM:9
Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.
ok
ok
These are alarm states reported from your control board. We provide some information as to what these mean.
ALARM:2
And…
ALARM:9
Does this system have limit switches?
Here is a list of the Grbl Alarms and Errors to help in understanding:
I don’t think there are limit switches. I have the working area set to 19.75/25.52
I have reset the connection, still giving me the same issue.
Also got this- G-code locked out during alarm or jog state.
